Truck wont crank over with key but will with rigged up switch
Old Mar 11, 2007 | 02:01 PM
Dufrain's Avatar
My truck wont crank over with the key.Someone has rigged in a push button.They cut the white wire on the fuel shutoff solenoid and ran a new wire .What should I replace to get this thing fixed right.My solenoid has to be lifted also to get it in run position.It shuts off ok.thanx
Old Mar 11, 2007 | 02:49 PM
clutch1's Avatar
it wont crank or it will, but not start. might have to check voltage at the solenoid to see what your gettin or not gettin. ones hold in voltage the other is pull in voltage.
Old Mar 11, 2007 | 02:50 PM
TIMMY22's Avatar
sounds like the solenoid "pull" was down probably from a bad relay or a corroded wire. Somebody hacked something. check to see where the wire they spliced into the white wire connects.
Old Mar 11, 2007 | 03:04 PM
Dufrain's Avatar
I hooked the large white wire back together like it was from factory.It is one of the 3 wires in the oval plug that goes to the solenoid.I have 12 volts to the relay on the fire wall.
txhawg
18
Jul 17, 2011 02:46 PM
bigredbrick
Apr 23, 2010 07:30 PM
stealman1
Nov 9, 2007 11:07 AM
12valve@heart
Sep 8, 2006 06:06 PM
JW3
Dec 26, 2005 07:10 PM
