Rod Knocking?
Old Mar 31, 2007 | 03:21 PM
kcredneck's Avatar
Rod Knocking?
Bought 2004 CTD motor knocks in the lower rear half of motor. 70,000 miles doesn't look abused. Is there anything else it could be?
Old Apr 1, 2007 | 01:30 AM
FMB's Avatar
FMB
Sounds like it might be a warrantee item to me.
Old Apr 1, 2007 | 01:32 AM
Jeff in TD's Avatar
On a common rail injection system if an injector leaks into the cylinder it will cause a knock.
In a gas engine, when an injector continues spraying when it shouldn't, it will make the mixture go rich, may foul out the spark plug, and may wash lubercant off the cylinder, and dilute the oil in the crank case.
In a diesel when that happens, mixture isn't an issue so the fuel will burn, but the added fuel will increase the temp of that cylinder, maybe enough to toast the piston.
At least that's my understanding. I would guess a good mechanic could tell the difference by listening.
I think I've only heard of one spun rod bearing on a later Cummins, so I think bad injector would be more likely.
If it's under warranty, I'd let a good dealer mess with it.
Old Apr 1, 2007 | 09:29 AM
kcredneck's Avatar
Thanks for the help and advice. I hope it is an injector and not a rod. No warranty salvage title vehicle.
Old Apr 3, 2007 | 05:48 AM
Stamey's Avatar
I just pulled a 2004 apart and fould a dropped valve in number 6. The noise it made wasn't very loud though. It was more like a tapping than a knock.
The best thing this could be, if it is an auto tranny, is loose TC bolts. I bought a truck once, dirt cheap because it had a "rod knock", and when I got it home I found the TC bolts loose. Tightened them and had a great truck, with no knocking.
Chris
ddestruel
Dec 7, 2008 06:37 AM
Badd Dogg Guy19
Jan 18, 2008 09:19 PM
wantabee
Mar 14, 2004 09:22 PM
BamBam
41
Sep 19, 2003 09:48 PM
BamBam
Feb 24, 2003 02:43 PM
