Removing shifter - NV4500/97
Old Aug 29, 2007 | 01:17 PM
ScottN's Avatar
Apparently tool 6783 is required, but I couldn't find an equivalent after looking many places. Apparently there is an alternate method... please enlighten me.
I'm hoping to get the trans out right away to get the flywheel down to the machine shop!
Old Aug 29, 2007 | 03:06 PM
Contractor's Avatar
If it is like my 96, you need to push down and turn the spring collar CCW. Two screwdrivers and a little muscle and it should pop out.
Old Aug 29, 2007 | 03:35 PM
dieselman2300's Avatar
Pretty much what contractor said, but I like to use 90* picks, for seals.
Old Aug 29, 2007 | 06:30 PM
robert chilton's Avatar
Same idea but I use a hammer and smack a screw driver at a 45 degree angle down and CCW. If you look close there is a corner for the screw driver to rest on. Works pretty well.
Old Aug 29, 2007 | 10:15 PM
ScottN's Avatar
After some struggling, I popped it out with only my fingers! I am superman haha!
I ended up getting delayed with a friend and beer... the tranny itself should come out tomorrow. I had to angle grind some of the bolts down to size on the drive shaft support bearing, as I don't have metric extended sockets... other swearing and cursing also occurred.
Old Aug 29, 2007 | 10:31 PM
Dodge359's Avatar
Wait til you put it back on.
CTDkid
Nov 20, 2008 12:04 PM
jimlj
Nov 10, 2008 12:47 PM
Box5
Apr 17, 2007 06:22 PM
justagoodolboy
Mar 20, 2007 07:33 PM
JMOS4
Mar 6, 2005 11:52 AM
