removing front brake rotors on 2wd
Old Oct 4, 2008 | 04:50 PM
jerry007's Avatar
Any tricks to removing the front brake rotors on a 2003 2wd? Thanks for any input.
Old Oct 4, 2008 | 05:34 PM
Smokin98.5's Avatar
2wd is easy. Nothing should slow you up on it. 4wd are a BiT**.
Old Oct 4, 2008 | 06:05 PM
johnh's Avatar
i don't know if they are the same as mine. here's what i did......... after removing wheel, remove caliper bolts, 1 upper and 1 lower, (they are tight!) remove brake hose, push pistons in a little bit with a screwdriver so the pads clear the rotor slide caliper assy off and set it aside.... at this point i use a C clamp to push the pistons in and getting rid of all the old brake fluid.
put a small container under the hose you removed to catch the fluid draining from the master cyl.... now you are ready to remove the rotor.
if you have a oxy acetylene torch it works faster... if not use a propane torch and heat the rotor in the area of the wheel studs all the way around.... as soon as the heat expands the rotor enough you can grab with gloved hands and pull it off, you may have to rap it a little with a hammer....... i have done a lot of rotors this way.... it takes longer to tell about it than to do it
Old Oct 4, 2008 | 06:13 PM
johnh's Avatar
4x4 are the same as 2x4 in that year
Old Oct 5, 2008 | 01:47 PM
jerry007's Avatar
Thanks for the info guys, sounds simple enough.
93ramrod
Apr 26, 2011 02:56 AM
catguy
Aug 31, 2010 03:43 PM
96_12V
Apr 25, 2008 05:41 PM
04ctd
Aug 3, 2007 04:19 AM
jethroish
Mar 31, 2005 06:16 PM
