removing rear disk brake rotors
Old Aug 28, 2010 | 05:15 PM
catguy's Avatar
i ve got and 02 3500 and cant get the rear brake rotors to bugde cant en one tell me what iam doing wrong
Old Aug 29, 2010 | 10:57 AM
wyododge's Avatar
Get a bigger hammer...
There is a solution to it. It might be in the wiki, or the FAQ's. Can't remember where. Do a search. I'll see if I can find it too.
http://wiki.dieseltruckresource.com/...ng_Brake_Rotor
Old Aug 29, 2010 | 12:46 PM
BarryG's Avatar
I just went through this. In the end a BFH was the key. Obviously remove all that needs to be removed. Then what ended up working for me after I used oil and heat since my first hammer didn't do it. I got a bigger hammer then would whack it turn it a bit (the backing plate was in the way and only had one little space to hit it in) and whack it again. I think the relatively even whacking pressure made the difference. That way the rotor doesn't get bound up on its way off. It still took a while but after a few hits and turns I could definitely tell it seemed to be working. I can say that since I was replacing my rotors I didn't care if they got damaged and they did as I hit the heck out of them.
Old Aug 29, 2010 | 02:26 PM
catguy's Avatar
i figured it out you have too take out the axles and the inner nut and pull the hub and rotors off its pretty esay thanks for all the help
Old Aug 31, 2010 | 08:18 AM
Silver_Ram's Avatar
When I removed the rear my rear rotors, I didn't have to take the rear hub apart. I have learned that if a rotor is uncooperative, spray liquid wrench or wd40 around lug stud holes, let sit for a few minutes. Make sure e-brake is off and with the truck on jack stands, put trans in neutral. I use a small piece of a wooden 2x4 and a big hammer. Rotate the rotor as it starts to pound off. Eventually they all give up..
Old Aug 31, 2010 | 03:43 PM
Tate's Avatar
The point that is lost in this thread is that 3500 pickups with discs, the disc actually bolts to the hub. You have to remove the rotor/hub assembly and then unbolt it from behind. They don't slip over like on the 2500's.
mhuppertz
Apr 3, 2010 05:14 PM
winkdemon
Aug 3, 2009 04:13 PM
jerry007
Oct 5, 2008 01:47 PM
cconrad331
Jan 27, 2008 09:47 AM
DSjockey
34
Jul 20, 2007 07:03 PM
