Release Bearing
Old Oct 3, 2009 | 08:47 PM
Jim Lane's Avatar
Post Release Bearing
I am replacing a Sachs clutch on Will’s 1st. Gen it has a 5-speed Getrag with transfer case attached.
Is the release bearing supposed to ride against the diaphragm all of the time even when the clutch pedal is released or is it supposed to retract like a normal manual transmission does off the fingers of the diaphragm?
I will be replacing this tonight, thanks in advance.
Jim
Old Oct 3, 2009 | 11:42 PM
Hydraulic clutches always have a little contact.
Old Oct 4, 2009 | 07:49 AM
Jim Lane's Avatar
Thanks Dave,
Ran into a little snag, the clutch on the truck was a LUK so all of the bolts are 1 1/2" too short; going to pick up some Grade-8 bolts in the morning.
Was a LUK used as a stock unit or is it an after market?
How are these compared to a Sachs?
Jim
Old Oct 4, 2009 | 02:24 PM
ofcmarc's Avatar
Sachs was stock. LUK is an aftermarket and dosen't appear to hold very well.
Old Oct 4, 2009 | 04:28 PM
Jim Lane's Avatar
Thanks,
The LUK pressure plate is about 20 pounds lighter that the Sachs and the Sachs disk has 8 springs while the LUK only has 5.
It looks like something you would use behind a gas engine
Jim
Rattletrap1
Jul 11, 2007 12:12 PM
graybig
May 18, 2007 08:08 PM
wadecool
Jan 12, 2007 11:39 AM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
