Rear end needed FAST
Old Mar 14, 2004 | 01:37 PM
PontiacNUT's Avatar
I just posted 2 wanted ads. Thank God for want ads. I lost my rear duals at 60MPH and destroyed the rear axle housing. I'm not wanting to use axle surgeons because the gears are bad too. I would like a Dana 70 3:54 ratio limited slip if possible. I will buy a rear end only or whole parts truck. What do you have? Mine has a utility bed so the spring centers are 43 1/4" center to center. 57 1/2" Backing plate to backing plate. Thanks, Steve Snyder765 748 3105 ANYTIME
Old Mar 14, 2004 | 04:28 PM
Haulin_in_Dixie's Avatar
Steve the only difference in width is the cab and chassis which is narrower. If that is what you have either rear would work just fine, just have a wider stance with the pickup rear. I like the wider rears, mine is 8'2" outside to outside.
Old Mar 14, 2004 | 06:12 PM
jaconst's Avatar
call a major salvage yard and have them do a national search for you, just an idea
Old Mar 14, 2004 | 11:12 PM
PontiacNUT's Avatar
Ya I did. they could only find 4. $1200-$2200 plus delivery! Ouch. So I figured I could find a whole wrecked truck for that. Indeed I did find one that was just fine for $2400. It was an old phone truck 1989 with 140K. But there was a guy looking at it first and bought it when I started looking at it. What a bummer. So close.
Old Mar 14, 2004 | 11:16 PM
I may know where a first gen rear is, don't know the ratio, but I am in Alabama.
Old Mar 15, 2004 | 09:55 PM
Stamey's Avatar
Check out
http://www.car-part.com/
I see a lot of them out there, and for less than a grand in some cases.
Chris
Old Mar 16, 2004 | 07:37 AM
PontiacNUT's Avatar
Thanks, Stamy. One of the best parts sites I've seen. And I've seen many in the past month.
I went ahead an hired "Axle Surgeons" to replace the "spindle on the drivers side rear housing. Cost $650! then I had to buy a backing plate, bearings and seal, brake hardware etc... Final cost about $800! and the posi unit is still bad! Need to choke on that project next. Thanks everyone. I will definately go to http://www.car-part.com/ FIRST next time. Steve
Jim Lane
Dec 7, 2015 09:16 PM
EdmontonCanada
37
Dec 9, 2009 03:18 AM
doorguy
Jun 8, 2007 06:19 AM
trik396
Mar 14, 2007 07:57 AM
PontiacNUT
Mar 16, 2004 07:39 AM
