Radiator
Radiator
I turned the plastic pet to drain the radiator. This worked well. It will not
tighten up. Just keeps turning.
Need some recommdations and suggestions? Hope I do not have to pull the radiator and if so can it be repaired?
Thanking you in advance for any information.
2005 - 2500 a/t 2wd.
Cummins Guru
Unscrew it and pull out valve and you will see how it works to tighten. Very cheap designed valve, happen's to me every time I do cooling system service.
radiator
Hey thanks for the reply, yes, petcock. This terrible radiator word was deleted in my original post.
I tried unscrewing and pulling the petcock out, but will not happen. Do I need to use pliers for this? Or I must have become very weak in my old age,
hahaa. I will give it a try tomorrow.
Thank you very much for the suggestion. Just I can remove the petcock.
How is this accomplished? It just spins.
thanks
thanks
radiator
I am not sure if the 2005 is the same. Seems different. I followed the manual
but something is not working. I do not want to pull that radiator, big job and not time. Or I work all night and take it to a radiator shop. Not sure what is actually going. I have never seen a petcock like this. Hope it is not broken.
radiator
Has anyone had this problem and were you able to put in a brass petcock system? If so, were able to do this while radiator is still in the truck?
John, I did find a wholesaler and can get a new radiator for a mere $425.
Must be a simpler way? A $35,000. pick up and a crap petcock. I agree with you bigiron. Never seen anything like this.
I see that you tried to push the draincock inward,then turn it a I mentioned in the other thread. It may be necessary to check the o-ring and make sure that it is properly seated. If so, put some waterproof /silicone grease; ie plumbers grease, on the o-ring to make it easier.
Do not use petroleum based grease or lubricants on the o-ring as this causes o-rings to swell up and or fail.
radiator
Hey:
Hercules, BigIron70 and Dr. Dizzle. Thank you very much for your suggestions. IT WORKED! and it is working. Will take it out for a ride to be sure this afternoon.
BigIron70, I used a small pair of vise grips to get the drain plug out and you
are correct, WAPOS system it is. I will be checking with a good radiator shop
to see if they can put in a brass plug system for future use.
Really appreciate the suggestions, especially on a big football weekend.
At least I do not have to buy a new radiator as one person suggested.
My thanks to all of you again. This is a great forum and the first time I had to
ask for assistance. Am sure it will not be the last. Put in zerex 05 anti freeze
and distilled water.
2005 - 2500 2wd, a/t Red in color stock engine, use for pulling my travel trailer and sometimes drive to work.
8liter
Sep 22, 2012 10:19 AM
SmokinDodge12V
Dec 1, 2002 08:44 PM
