Quick Connector needed. NON standard. HELP.
Old Jun 3, 2008 | 11:01 AM
judgedredd's Avatar
Hi, I have been having problems locating a connector for my '95 Dodge ram 1500 5.9L (Standard Cab Long Bed). Unfortunately the Dodge people in Amarillo Texas put on a non standard part (after taking a week to try replace line). It has been steadily leaking for about 9-10 months and is getting worse. I have a new transmission cooler line but the connector shown in the picture is very hard to locate. The connector circled in white is what I am looking for. It is a compression fitting and the tube has bent which is where the leak is coming from. If anyone has a straight flared connector stem that would be a great help. The stem size is 1/8". Not sure the nut thread though.
Here is the url of the images:
http://matrixfiles.com/truck/truck.html
Thanking everyone in advance of any help that they may give.
Email me on cas@art4houses.com.
Old Jun 3, 2008 | 01:50 PM
1-2-3's Avatar
Just a plain ole guy
That's not a compresion fitting. It's a flare fitting. It also looks like copper tubing installed with it. I don't think your suppose to have copper and flare fittings on transmision lines. You can get what your looking for at a home repair center. (Lowes, Home Depot). You don't replace the nut. You replace the tubing and use a flaring tool to create a new flared end on the new tube. Your going to need flaring tools to fix this.
You be better off ordering new lines, or even better, finding a transmision shop to make some new lines.
Old Jun 4, 2008 | 12:00 AM
judgedredd's Avatar
Thanks
Hi charliez,
I thought that I might have to go that route. I went to any radiator shop (since this part was on the radiator side of things) and they found a connector very similar to the one in the picture. This one came off another radiator and this time the nut is brass. The stem is still copper/brass. Only problem is that the stem is bent at right angles. So I am considering cutting off the flared end to where the stem is straight and has the quick connect flange (sorry about the incorrect nomenclature, this is a new area for me). What would be a good company to get a flaring tool from?
Thanks.
Old Jun 4, 2008 | 07:13 AM
1-2-3's Avatar
Harbor Frieght, Lowes, Home Depot, Sears, any plumbing supply, etc
Old Jun 5, 2008 | 10:24 PM
duner's Avatar
actually that may be a swage-loc fitting.
http://www.dieselmanor.com/dm_products/DM-CLG3.asp
Old Jun 6, 2008 | 04:19 PM
judgedredd's Avatar
By the way, the vehicle is gas powered not diesel.
estesbubba
Aug 13, 2008 08:38 AM
txs
Sep 25, 2007 03:07 PM
Tommy93w350
Aug 6, 2007 06:27 PM
moparguy
Mar 28, 2006 07:43 PM
Bad Ramer Jamer
13
Jan 31, 2006 02:13 PM
