PSD CPS diagnosis and change
Old Jun 27, 2006 | 10:54 AM
tool's Avatar
I'm thinking the problem with my '99 F350 PSD is probbaly the Cam Position Sensor.
Can anyone tell me the symptoms of this sensor going bad and where it's located on a PSD?
Old Jun 27, 2006 | 11:01 AM
JD Dearden's Avatar
The truck will just shut down at anytime but it is usually at low speeds. It will get worse and worse overtime. I have owned 3 psd
Old Jun 27, 2006 | 11:02 AM
Cowhand's Avatar
Right above the crank pulley...it's a plug looking thing with a harness that plugs into it.
Causes hard starting or no starting, sometimes the truck will just quit. Buddy of mine just had to replace his.
CPS is about the only thing that ever goes out on the 7.3.
Try this link for a replacement, best price I've seen http://www.dieselpowerproducts.com/ford
Old Jun 27, 2006 | 01:36 PM
Partsman's Avatar
Does it start right back up when it dies? Do you have a chip in it?
Old Jun 27, 2006 | 02:52 PM
1-2-3's Avatar
Just a plain ole guy
My neighbor has this same truck and had the same issue. He mainly does highway driving, and his would shut down just like someone turned the truck off while driving and chunked the keys out the window. Had to roll to a stop. Sometimnes it would start right back, sometimes not. Had 80 miles left on his warranty and the local Ford guys towed it in and fixed it under warranty. I think it was an $80 part. You can change it yourself.
Old Jun 27, 2006 | 11:25 PM
tool's Avatar
No chips or mods, bone stock, problem has been getting progressively worse.
Sometimes it will restart, sometimes not. If left to sit for several hours it usually restarts.
A real pain in the butt. I got a new CPS today so hopefully that will fix the problem.
Truck has 200,000 miles. Most of which are fairly heavy towing. (ie 15-20,000 lbs)
Usually does it at low speeds.
Old Jun 28, 2006 | 07:04 AM
fccparts's Avatar
when it shuts down try cranking it over on a 99-01 if the tach dosn't move u can be assured its a cam position sensor
Old Jun 28, 2006 | 11:29 AM
tool's Avatar
Yep, I'm pretty sure that is the problem. when it quit again yesterday I cranked it quite a bit and the tach never moved. I'm going to go change the CPS. Hopefully that fixes it. Thanks for all your help.
Grider Pirate
Oct 10, 2007 11:00 PM
sitdownsteve
Aug 24, 2007 12:31 PM
John In NC
Oct 22, 2005 09:14 AM
Supernova
Sep 9, 2005 03:09 PM
welder27
Sep 15, 2004 11:56 PM
