Problem starting now
Old Dec 19, 2009 | 05:29 PM
Skidoo01's Avatar
Angry Problem starting now
i have a 2000 dodge ram 2500 with the cummins with the 5.9. since i bought the truk the tac has been going crazy sometimes it will stay on Zero other times it will bounce around. when this happens i seem to loose power. but when the tac starts to work right again the power comes right back. and now with it gettig colder it seems to be doing this more and more. this morning i went to try to start the truck and it didnt want to start because of the cold, when it did satrt it quit a few minutes later and it still wont start.. Does anyone know what could be going on here. it would be a great help. thanks
Joe
Old Dec 19, 2009 | 05:33 PM
cminzey's Avatar
I know some trucks have had the AC wire scuffing problem ck your AC wires and make sure they are not chaffed through the casing
Old Dec 19, 2009 | 05:36 PM
Skidoo01's Avatar
thank you i will have to check that out
Old Dec 19, 2009 | 07:15 PM
rich's Avatar
could be cam sensor try and pull some codes and see what you get
Old Dec 19, 2009 | 08:30 PM
pind's Avatar
that one really sounds like a cam sensor problem.
The chafing wires were a problem on the 3rd gen trucks, under the AC compressor.
Old Dec 27, 2009 | 01:36 PM
Skidoo01's Avatar
when i put it on the computer i get an over boost pressure code?
Old Dec 27, 2009 | 02:08 PM
johnh's Avatar
Joe
cps (crankshaft position sensor) is most likely your problem.
it's location is above the starter in rear of engine near flywheel.
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
Brad5502
May 22, 2009 12:29 AM
abc4yew
Mar 15, 2007 11:55 PM
cumminsdriver635
Oct 16, 2004 05:08 PM
