Power steering pump replacement prob.....
Old Mar 28, 2009 | 09:48 PM
boyd050's Avatar
Hi there, I decided to replace my power steering pump on my 2002 dodge 2500 diesel, I picked up the new one, slid it in place ensuring the shaft is slid in the right way, by hand lined up fine, filled it up , run it... no power steering, took it off , done this 3 times, put it back on , every time, no power steering, am I missing something here? all the lines are on properly, the shaft slides in place easily, new fluid, still... doesn't work, I can't see the new pump being shot, it has to be me, what about the valve that the threaded pressure hose goes into, should I change that off my old one to the new one?? not sure... can't seem to get it to work, hoping for a suggestion.... thanks.....!
Old Mar 29, 2009 | 02:12 AM
Crimedog's Avatar
It is possible that it is an air-locked pump. When I replaced my steering box my pump dumped its fluid on the ground and wouldn't give me any power steering when I refilled it. I took it for a drive, then let it sit for a couple hours trying to figure it out, and when I came back it had finally taken the fluid.
When you fill it, is it using any fluid or is the level staying the same? If it is staying the same, and you drained the lines out my bet is on an air pocket.
Old Mar 29, 2009 | 09:39 AM
boyd050's Avatar
power steering
thanks, the level seems to stay the same, doesn't change, is there any way to bleed these? or do you have to armstrong steer it out? I think today , I'll jack it up and see If I can get the wheels to turn at all, if not, I guess I take it out for the 4 th time but I would really like to avoid that. especially since it snowed here a bit last night....
Old Mar 29, 2009 | 11:16 AM
2stroke's Avatar
get the front end up in the air and move wheels manually, then move to steering wheel.
Old Mar 29, 2009 | 11:59 AM
1985cucv's Avatar
yes jack the front end up and move the wheels all the way back and forth shut truck off and check the fluid. mine foamed like a sob when i first did it. i let it settle filled it up ran the truck and kept doing the same thing until it didnt foam.
Now there is a possibility that you could have destroyed the new pump if debris and such was still in the lines. but it is unlikely hopefully this will help
Why did the pump go out the first time?
Old Mar 29, 2009 | 12:01 PM
1985cucv's Avatar
oh by the way do these trucks have the hydroboost set up or a vaccumm pump to run the pump? if it is the hydroboost push your brake pedal down as the brakes are run off of the ps pump too that might help
Old Mar 29, 2009 | 01:16 PM
johnh's Avatar
here's the procedure from the manual
Old Mar 29, 2009 | 02:47 PM
boyd050's Avatar
thanks
Thanks everyone for your help, I finally got it today,!!! after RE an Re 5 times, seems there was lots of air in the systerm, so I loosened it off at the brake assist point, cranked her up and blew oil and air all over, tightened it back up and that solved the problems.... so all that work for a **** air bubble......... thank again for all your information!!!!!!!!!
Puke
Nov 30, 2010 07:18 PM
jay_d
Dec 9, 2009 08:51 PM
Elohim1
Apr 18, 2009 07:55 AM
AWAC
Dec 13, 2005 01:51 PM
