now what
Old Mar 25, 2009 | 11:01 PM
george_girouard's Avatar
now what
Okay guys I just changed out the vp 44 and now my truck won't start. It just keeps turning over and won't fire any ideas? It did coughed a few times I have a 2001 ram 3/4 ton 24 valve diesel.
Old Mar 25, 2009 | 11:26 PM
johnh's Avatar
did you bleed the injectors?
Old Mar 25, 2009 | 11:39 PM
johnh's Avatar
to bleed them ,loosen the first three slightly (the ones that are easy to get at) and crank engine until fuel comes out, tighten them and start engine...... it will run rough for a while but will smooth out as soon as all the air is purged
Old Mar 26, 2009 | 04:13 PM
Dinner's Avatar
May have to close off injector lines one at a time (if fuel doesn't come out of all 3 at the same time). Once fuel comes out of one of the lines, close it off. Begin cranking again until fuel comes out of another line, close it off. Do the same step to the third line.
Even with 2 lines getting fuel sometimes you'll be lucky and the engine will fire and begin to run.
Good Luck, by the way; is your fuel pressure good, feeding the VP?
Old Mar 26, 2009 | 06:04 PM
19Fury69's Avatar
I find holding the throttle down about an inch helps out alot. Just until it starts then let it idle.
Like everyone else said, you will need to bleed the injector lines to get all the air out before it will start.
Old Mar 29, 2009 | 05:24 PM
Chaser10's Avatar
Changed VP44 on practically same truck as yours this weekend. Took bleeding the injectors one at a time before it finally started (4, 3, then 1).
moparmatt
May 1, 2015 08:49 AM
Shorts
Jun 29, 2013 09:23 PM
95ram
Jul 28, 2010 02:17 PM
ramlovingvet
Mar 22, 2003 08:32 PM
cfm3110
Mar 18, 2003 10:54 AM
