power steering pump
Old Apr 17, 2007 | 03:10 PM
brendangsxr's Avatar
Question power steering pump
hey guys i'm lookin for a microfiche of the powersteering pump any ideas on where i can get it.I'm also looking for the directions on the dissasembly of the pump and the installation on the pump rebuild kit.
it's for an 89 250 with the 12 valve cummins and the pump doesn't run off of the belt
Old Apr 18, 2007 | 04:21 PM
Bad Ramer Jamer's Avatar
Try ebay. There was a guy on there when I was into El Camino's selling micro fish for all kind's of stuff.
Old Apr 19, 2007 | 10:35 AM
b4wheeler's Avatar
Are you looking to rebuild the power steering pump or the vacuum pump?
The power steering pump is mounted to the back of the vacuum pump and it is usually the seal in the vacuum pump that leaks.
Check to see if it if power steering fluid or engine oil that is leaking.
There is a guy on Ebay that sells vacuum pump rebuild kits...www.fixinrams.com
tony99
Apr 9, 2014 08:25 AM
DodgeCowboy
Aug 28, 2006 08:57 PM
powerwagon440
May 25, 2003 02:31 PM
amartinson
0
May 4, 2003 01:55 PM
