Pinion nut size and question.
Old Dec 3, 2007 | 08:12 AM
Purplezr2's Avatar
Ok, I'm trying to figure the size of the pinion nut and have read like 4 different sizes.
I have a 2500 manual, open rear, D80 what size is the nut, I know I will have to machine it down some. Also with the yoke from an 2001 d80 dually fit in place of my stock on.
I need to know today as I need to buy parts asap.
Old Dec 3, 2007 | 09:36 AM
JD730's Avatar
Pretty sure it's 1 7/8" on our trucks.
Machine what? I didn't have to machine anything when I replaced my yoke. I couldn't break my loose with a 3/4 drive breaker bar with a cheater pipe. I wound up restraining the yoke with a 4 foot pipe wrench and using a 1" impact gun to get the nut off. Then you'll need a puller to get the yoke off the pinion. When I installed it I torqued the nut to 475 ft lbs.
The yoke will fit, just make sure it used the same size u-joint. It should.
Old Dec 3, 2007 | 09:54 AM
Purplezr2's Avatar
Thanks I heard you have to machine the socket cause the side wall are to thick.
Old Dec 3, 2007 | 09:59 AM
JD730's Avatar
I see, I guess the socket I used was just right.
ATEAV8GN
18
Jan 24, 2018 12:28 PM
1985cucv
Jul 16, 2009 10:49 PM
CTD NUT
Mar 8, 2005 08:32 AM
ATEAV8GN
Jan 13, 2003 03:24 PM
