P0760 code
Old Apr 26, 2021 | 10:11 PM
seaowl78's Avatar
P0760 code
so i have traced an issue back to a P0760 code. the shift solenoid has been tested and replaced with a confirmed good solenoid. the other transmissions sensors have been replaced on a recent rebuild.
i believe i may have a broken a wire going from the ECM to the Shift solenoid, im have started to attempt to check the connection above the motor and found out the are some addition wires.
dose anyone have the pin out of the transmission connection plug and the ecu plug? or engine connection
im also open to other suggestion to the P0760 code since it has my transmission stuck in a Limp mode.
Old Apr 27, 2021 | 10:47 AM
FMB's Avatar
FMB
If you edit your Signature, you are less apt to forget to tell us what vehicle you are asking about as it will appear in each of your postings.
Back to morning brew . . .
Old Apr 27, 2021 | 12:01 PM
seaowl78's Avatar
Thank you! i will do that now
dccjml
Jan 2, 2010 10:37 AM
roadrage1
Jun 1, 2009 07:25 AM
Redliner
Mar 27, 2009 08:05 AM
CTD600
Jul 19, 2007 12:03 PM
KYcountry
Mar 19, 2007 11:15 AM
