Out of park
Old Feb 12, 2009 | 12:23 PM
zill's Avatar
Out of park
I cannot get the gear lever out of park. Any suggestions
Old Feb 12, 2009 | 01:31 PM
Brian08Q35004x4's Avatar
From: This Nazi state of California 2nd home Gilbert AZ under God
Are you stepping down on the brake?
Old Feb 12, 2009 | 01:57 PM
zill's Avatar
Yep... I have two of theses trucks and have driven them over 150,000 miles without incident. The BTSI solenoid seems to be stuck. Does anyone know how to disconnect or remove that solenoid?
Old Feb 12, 2009 | 03:02 PM
madhat's Avatar
Administrator/Jarhead
Is the steering wheel locked? I'm not trying to talk to you like you are unintelligent, but grab the steering wheel and turn it a little one way, then the other and try to pull the truck out of park.
Old Feb 12, 2009 | 04:27 PM
jnicewan's Avatar
check your brake lamps the brake lamp switch or fuse could be bad. might be able to turn your key to the off ( not lock position to shift out of park too )
Old Feb 13, 2009 | 07:37 AM
zill's Avatar
I had to pull the adjustment clip to get it to move. I think i have a bad solenoid.
SOhappy
Oct 17, 2006 10:14 AM
GoodoleBob
Oct 6, 2006 06:07 PM
carcrz
Sep 18, 2006 10:43 PM
CanuckRam
Aug 28, 2006 08:03 AM
