out of gas
Old Jun 3, 2006 | 09:21 AM
chadwick's Avatar
out of gas
alight guys i ran out of gas right as i pulled up to my house. I went and got 7 more gallons put it in there. Let the lift pump run 3 or 4 times and the tried to start it and it wont start. how do i get all the air out of the lines
Old Jun 3, 2006 | 09:37 AM
Geico266's Avatar
Before anyone else starts flaming you, if you put gas in a diesel truck, you have a real problem.
Now that we have corrected your choice of words lets get your truck started.
But first, a word from an old diesel driver. NEVER let your truck get below 1/2 around town. It is hard on the LP, and the fuel can heat up when below 1/4 tank due to it being used for cooling. You are not saving any money but running on "E", and doing what you do just cost you time , money, and possible damage to starter (cranking hard), sediment getting into the fuel system, and having to listen to me. In addition, being prepared for an emergency you would have to stop and get fuel if you had to leave in a hurry. Everyone else would be stopping for fuel also. Be smarter than the crowd, it might save your life.
If your lift pump is weak (or not working) it will not do you any good to bump the starter to run the LP. You may hear it run, but it may not be pumping anything. You need a fuel pressure guage.
Try cracking open the fitting on the down stream side of the fuel filter and see if you are getting fuel to the injection pump.
Next, take a 3/4" wrench and crack at least 3 lines at the injectors...crank & crank until the air is out and truck is about to run...tighten the lines and crank'er up.
Fill it up and keep it there.
Old Jun 3, 2006 | 03:50 PM
chadwick's Avatar
ALIGHT i cracked the lines at the injectors and i got plenty of fuel coming out of them. Another thing is that when i am cranking it the motor sounds like it has a lope in it. Do you think i picked up some stuff in the bottem of the tank and it clogged one of the injectors
Old Jun 3, 2006 | 04:37 PM
chadwick's Avatar
alight guys i got it runnin thanks for the help
Old Jun 3, 2006 | 06:18 PM
Geico266's Avatar
Glad you are back on the road.
Keep it between 1/2 & full, and get a FP guage. You'll thank me when you save your $1,500 IP.
cappykd
Jun 23, 2008 04:45 PM
THURENfab.
Aug 8, 2007 07:02 AM
Scovo1
30
May 11, 2007 01:08 PM
04ctd
15
Apr 30, 2006 08:45 AM
DesertTRD
Dec 6, 2002 01:57 PM
