???Oil TOO clean??????
Old Jan 26, 2007 | 07:44 PM
Chrisreyn's Avatar
Exclamation ???Oil TOO clean??????
OK.. kinda worried here....
Changed the oil and filter on the truck on the 5th of January, and have driven just over 500 miles since.
prefilled the filter and everything went fine.
Just checked the dipstick and the oil level is "full", but what was scary is that the oil is so clean it looks like it just came out of the bottle...
My last truck and th Ford I had before it, the oil would turn black as spades as soon as you turned the truck over. I would have thought even just sitting in the sump it would pick up enough crude to turn black.
The oil on the dips tick was warm to the touch, and so is the filter. There is no smell of diesel fuel or signs of coolant in the oil.
When I start the truck, the oil pressure gauge drops to zero then rises to the normal operating range.
Engine sounds fine, but I am worried something is wrong....
I mean, shouldn't the oil be black by now? Is this a sign of a major problem?????
Scared to start the truck now.....
Old Jan 26, 2007 | 07:57 PM
badme's Avatar
Mine is the same way. I bought this truck on the 10th of January and the dealer had changed the oil, I have been about 800 miles now and it looks just like new oil just poured in. I had 2 gm diesels before this and the oil was black as spades before it got out of the garage.
9812v's Avatar
I changed mine 2000 miles ago and it is still really clean, I think you are fine. I have never owned anything else that stays clean for so long.
Geico266's Avatar
Relax! Man, you are a worry wart.
Just don't HIT anyone this time, and make sure you have FULL coverage!
A man shouldn't have to sell his horse to pay for body work.
Old Jan 26, 2007 | 08:12 PM
Chrisreyn's Avatar
OK thanks guys... I kinda freaked out, can afford anything major right now and this is my only vehicle...
I took it for granted it should be filthy by now... its cleaner than the BOSS's Grand Am's oil and they were changed at the same time....
Thanks again.. sorry for the panic...
and Gieco, I got FULL comprehensive( thru Gieco none the less) and am avoiding that particular intersection...
Old Jan 26, 2007 | 08:20 PM
Geico266's Avatar
The previous owner may have run synthetic oil in it before and that will keep the crankcase cleaner. Just a thought.
Lizardguyout.
Old Jan 26, 2007 | 08:28 PM
Howy's Avatar
Mine usually stays pretty clear until its been run through a few thousand miles. When I change my oil its usually every 6 months since I dont put the miles on my truck lately. Its usually fairly black and has the diesel smell to it by then though.
Be happy its clean!
Old Jan 26, 2007 | 08:41 PM
blackdiesel's Avatar
Registered
mine gets as black as night after the first startup! reckon its all that soot
Old Jan 27, 2007 | 11:42 PM
PaulDaisy's Avatar
How can one possibly be unhappy about oil being clean? Like, the rings are holding too much gunk in the cylinders, why is it not in my oil? I can understand not liking it when it is as filthy as sin, like mine... I wish mine was clean.
-P
Old Jan 28, 2007 | 07:13 AM
TIMMY22's Avatar
mine stays clean for 2000 miles.
I had to change my oil pan last fall. absolutely no sludge or grit or anything in the bottom of the 10 year old pan.
Old Jan 28, 2007 | 08:29 AM
SMOKNISB's Avatar
Mine was clean as new for the first 4K miles, and is getting darker the longer I run it.
Old Jan 28, 2007 | 12:20 PM
bumpytruck's Avatar
My 91 stays clean for quit awhile,when I changed it on my brand new 05 I thought something was wrong,it was filthy in just 100 miles ,but after reading on here ,Ifound that it was normal.
Old Jan 29, 2007 | 06:49 AM
Chrisreyn's Avatar
Eery deisel i have ever owned has been that way, thats what threw me about this..guess i should be happy and not worry about it.....
Old Jan 29, 2007 | 08:01 AM
hoghead's Avatar
I have 2500 miles on rotella syn. 5w40 and It is still pretty clean. p.o. must have kept the oil changed regularly. At work I drove a 7.3 powerjoke and a 6.2 shivy diesel and as soon as the oil was changed it turned blacker than a coal bucket.
Old Jan 29, 2007 | 11:02 AM
HappyGA's Avatar
see chris, i snuck out there and changed your oil while yall were sleeping. Just trying to earn some brownie points with you before I come out there to court your daughter...
