oil pressure light is coming on and off
Old Nov 26, 2005 | 09:08 PM
eddie harris's Avatar
at times while driving the oil pressure gauge falls to zero,check engine light comes on and then returns to normal with noother problems
Old Nov 26, 2005 | 09:43 PM
Geico266's Avatar
Oil pressure sending unit is probably bad. Get a new one at the parts store then find it on the truck.
Have you checked the oil?
Old Nov 26, 2005 | 09:46 PM
Well that was the first thing I did, I actually check it every time I drive it. The check engine light will come on when I'm driving down the road and the "oil pressure" guage drops to 0 for a few miles then goes back to normal. No ping, cracks, pops, nothing, no other mysterious sounds.
Old Nov 26, 2005 | 10:24 PM
COLDHEART's Avatar
Check the sender...buy aftermarket..MUCH cheaper.You can get to it through the drivers wheelwell
Old Nov 28, 2005 | 01:10 AM
Dr. Evil's Avatar
Very common problem....like the others said, just replace the sender.
#22: http://www.dodgeram.org/tech/dsl/mt_...l_sys_comp.htm
If you want to confirm, get a 1/8" NPT (0-100 psi) pressure guage from the parts store, take the 1/8" plug out of the housing that the oil filter screws onto and install the pressure guage there. Then start the truck.
Old Nov 28, 2005 | 06:07 PM
RAM2940's Avatar
Doesn;t say what year truck, but where can you find one aftermarket for a 2001. What i understand cummins does not sell one for a 2001 dodge anymore and the dealer is over 200.
caper
Jun 4, 2014 09:31 AM
Power Ram 250 C
Feb 20, 2007 11:08 AM
CTD_Neil
Jun 10, 2005 11:02 PM
Xplorer
Jul 2, 2004 03:00 PM
