oil gauge
Old Mar 17, 2009 | 07:10 PM
zmann's Avatar
oil gauge
The truck is running good, but the oil gauge is at 0. Nothings leaking either, so idk whats wrong with it, and im scared to drive it because i dont want it to lock up.
Old Mar 17, 2009 | 08:03 PM
halerazor's Avatar
my 98 would sometimes read 0 then it would read fine 10min later.
Old Mar 18, 2009 | 07:36 AM
1-2-3's Avatar
Just a plain ole guy
Usually a bad sending unit.
Old Mar 18, 2009 | 09:40 AM
infidel's Avatar
Replace the sender with one from Cummins.
Auto parts senders don't last, you'll be buying another soon if you go that route.
Old Mar 18, 2009 | 12:54 PM
thumper549's Avatar
The dealer will tell you to reflesh...DONT !!!! as that makes your gauge a fancy idiot LT.
Old Mar 18, 2009 | 01:05 PM
lovinCTD59's Avatar
I had this problem with my 01.5 The gauge would work for about 3 min. from a cold start then It would drop to 0 PSI for the rest of the day. It was the oil press. sending unit (Right side of the block just below the engines computer.) I replaced Mine with an Airtex from rock-auto. I could not find one around here if my life depended on it even from cummins.. Chances are thats your problem, but I would check the connection first.
Old Mar 18, 2009 | 08:36 PM
zmann's Avatar
Yep thanks guys, it was the sending unit. I just replaced it tonight. Thanks again for the help.
ian515
Oct 16, 2007 07:02 PM
rjm022
Feb 7, 2006 01:23 PM
TxDiesel007
15
Jan 18, 2006 01:19 PM
