oil filter?! urgent
Old Jun 22, 2005 | 05:17 PM
Ian's Avatar
Ian
oil filter?! urgent
where the hell is it? right in between the turbo and the motor? dumb question, but just want to make sure I've got the right one. All the other trucks I've had before have had the oil filter pretty close to the oil pan.
Old Jun 22, 2005 | 05:20 PM
phox_mulder's Avatar
Yes.
Passenger side of the engine.
phox
Old Jun 22, 2005 | 05:42 PM
Ian's Avatar
Ian
k, thanks
Old Jun 23, 2005 | 09:08 PM
Ian's Avatar
Ian
man, that was a pita to get it off...ended up breaking my filter wrench. whats the easiest way to get that sucker off for future reference? I disconnected the hose from the turbo to the bhaf, but it was still a bugger.
what a newb question
Old Jun 23, 2005 | 09:19 PM
CTD2001's Avatar
instead of using a typical large oil filter wrech that works well on most vehicles, buy just the piece that goes on around the oil filter. I have one that i can put down in there, slide around the oil filter, then it has a spot on it that i stick a 3/8ths extension in and connect it to my wratchet, it is a breeze to loosen and take off and then to tighten and on the new one
Old Jun 23, 2005 | 09:35 PM
Dr. Evil's Avatar
strap wrench....
be careful not to short on the alternator ( wrap my extension with electrical tape)...youll blow the main fuse
Old Jun 23, 2005 | 09:41 PM
AKDSLDOG's Avatar
Come up from the bottom and spin it off with you hand. When installing the new filter, dab your finger in clean oil and coat the gasket, spin the filter on with your hand as tight as you can and leave it at that. I have yet to loose a filter at hand tight and in my profession I' ve change a few .
Old Jun 23, 2005 | 09:49 PM
Dr. Evil's Avatar
hand tight...really?? I always use the ol wrench. Maybe I just dont have the patented "Kung Fu Alaskan death grip"....
Old Jun 24, 2005 | 07:37 AM
Ian's Avatar
Ian
Ok, thanks guys! I'm not going to be able to hand loosen it off, so I'll try the strap that CTD2001 and dr. evil suggested.
Cheers
Old Jun 24, 2005 | 08:23 AM
Mopar1973man's Avatar
Should be tighten 3/4 of a turn from when the gasket touches the mount.
I got luck once in awhile to twist one off by hand but rare...
Old Jun 24, 2005 | 09:06 AM
67HotRod's Avatar
All else fails, stick a screw driver through it...
Old Jun 24, 2005 | 06:36 PM
Ian's Avatar
Ian
almost did...
Old Jun 24, 2005 | 09:41 PM
About using a screwdriver...
If you go that route make sure to put the first hole in the bottom and drain it first.... Less mess that way...
Old Jun 24, 2005 | 10:40 PM
AKDSLDOG's Avatar
Being a heavy equipment mechanic, I have changed countless filters, very few "hard to reach places" do I need to use a wrench. On my pick up, I tighten it as tight as I can get it by hand and never had a problem, spin's off with hand. You can get a good grip on it from under niegh the truck.
I like that "KUNG FU ALASKAN DEATH GRIP" , First time I've heard that one.
Old Jun 26, 2005 | 01:18 PM
DZLPWR's Avatar
I pretty much do the same thing by tightening by hand, i also wipe the oil from the filter and my hands so i can get a good gorrila grip on it. I usually cant get it off by hand though. Thats were my strap wrench comes into play.
