not the ecm, no start
Old Jun 24, 2006 | 08:11 AM
J BODY's Avatar
If it were me.......there is a test tool at the dealer that can take the wiring and ECM out of the loop. I would drive it until warm so that I could get your truck to where it doesn't start, unhook the VP and install the test tool. If the truck doesn't start with the test tool hooked up you would be getting a VP. If it does start you'll need to look at the wiring and ECM side of things. Another thing you can try is when it's warm, get a transmission fluid funnel (long, small spout) and poor some cool water over the pump. If it starts after that, I would be looking at a VP.
Old Jun 24, 2006 | 06:50 PM
Smkndzl's Avatar
VP is the VP44 , sound like you having one going out , very common when summers comes around , you did have a fault , dont know what that code is, probably for pump timing code.
Old Jun 24, 2006 | 11:01 PM
J BODY's Avatar
.....which is where the special tool I mentioned above would come in handy. Sometimes when these trucks hot soak probs will arise. Try the cool water trick. I've started a few trucks over the years that were towed in no start by doing that. They got VP's.
Old Jun 25, 2006 | 09:23 AM
Copenhagenjunkie's Avatar
Let's see,
Only code you are getting is 1689, no others?
Hard starts when warm usually means the IP is going south.
What edge do you have?
Any hesitations or stalling when driving?
Answer Q's and I will get back with you.
Old Jun 25, 2006 | 12:03 PM
dodgetech77's Avatar
Injector pump! gets my vote
Old Jun 25, 2006 | 10:15 PM
Based on your response it has to be the VP. Reason I asked about the edge is I just took my ez in to get it checked. I was getting the 1689 code and severe hesitations and stalling. I ran w/o it for 500+ miles with no problems. I even put it on a friends '99 on friday and it did the same thing in about 3 miles so I drove down to Ogden to the Edge headquarters.
Sorry, time to start shopping.
Old Jun 26, 2006 | 04:27 AM
plow's Avatar
kxhonda has a thread in this forum also and he is having basically the same problems as you are. If you don't think its the vp I would start looking for a bad heat or temp sensor. In kxhonda situation his lift and Injection pumps were already replaced and he is having the same problems as you.
Old Jun 26, 2006 | 10:21 AM
Tree DR's Avatar
It's electrical. Where? What changes in the electrical system when it cools down? If I recall there's a computer in the pump? Heat expansion? Or other wires or connectors coatings getting hot and letting in or out electrical current. What sensor when hot won't let the motor start IAT, MAP, Fuel temp? Try the water over the Fuel pump (VP44) if that fixes it, that's probably it.
ratat98
Sep 18, 2016 07:34 PM
5.9Excursion
Cummins Conversions
Mar 20, 2008 04:47 PM
jrussell
17
Sep 17, 2007 06:38 PM
loosendend
Sep 4, 2006 12:01 PM
Ohio Joe
Jul 12, 2004 12:13 PM
