No Speedometer
the speed sensors are pretty notorius on these. is at the rear of trans or on the rear axle. but with the air bag lamp on too wiggle you key or move it slightly. you lock cylinder may be binding or ign switch could be acting up.
I'm guessing the VSS sensor in the rear diff just died.. Simple part to replace, not cheap and I could only get it from Dodge. None of the parts suppliers had stock in my area.
ridofpwrstroke
Mar 7, 2003 07:08 PM
