no reverse lights
Old Jan 6, 2004 | 07:37 PM
12valvelover's Avatar
no reverse lights
My reverse lights do not come on. I'v checked the fuses, the wiring and the bulbs and all are good. What else could it be?
94 2500 4x4 manual
Old Jan 6, 2004 | 07:46 PM
Craig93's Avatar
I actually had to replace my rev switch to sort mine out. Climb under there and jump the switch while someone is checking your rev lights. I guess if you had a test light confirming you have power coming in would be your first step...but if not revert to previous plan.
Old Jan 6, 2004 | 07:53 PM
can you tell me where exactly that rev switch is?
Old Jan 6, 2004 | 07:56 PM
Craig93's Avatar
On mine...left side of trans..just above the pan, should have 3 wires going to it if I'm not mistaken. Yours should be similar.
Old Jan 6, 2004 | 08:00 PM
Thanks, Ill check it out first thing in the morning.
Old Jan 6, 2004 | 08:05 PM
Dr. Evil's Avatar
Reverse switch is on the left hand side of the NV4500 near the back. There are 2 wires and a weatherpak connector...I just replaced one...this is most likely your problem.
dsljunkie
14
Dec 27, 2018 02:14 PM
tntshrekuk
Jun 25, 2008 12:02 PM
CHarlan
Aug 6, 2003 08:40 PM
soundfetish
May 9, 2003 04:40 PM
