No power..Help.!!!!!!!
My check light is on... Codes are.. P0237, P0238, P1475, P0523, I had the codes checked today. Replaced the MAP sensor and the Oil pressure sensor and hade the codes cleared. Started the truck and in a min. I hade the codes again, so I cleared them again but still they keep coming up. I tput my truck in limp mode and has no power..... My dash lights keep blowing the fuse when I turn them on, Could this be linked somehow... Please help....
before I did any thing else I would check and clean all the ground connections and check the batteries and there connections. With several diffferent codes it could just be an electrical problem even a short some where.
Figured it out!!! Edge comp box is bad, works intermitent.. sending it back for repair. Still cant figure out the dash lights though, checked all grounds and had the dash out, no bad wires. I'm think I have a bad dimmer switch.
powerwagon440
Jan 20, 2003 08:50 PM
pwabbott
14
Dec 20, 2002 08:23 PM
