No Overdrive or Lock-up!!!
Old Aug 17, 2007 | 07:41 AM
JIT's Avatar
JIT
I was driving to work this morning and truck shifted fine. Got off the interstate and onto the local highway and truck would not shift back into OD. Parked, checked fluids and let it cool. (trans temps were normal on the Juice monitor 148deg) Got back in and drove it another 10+ miles and still cant get it to shift into overdrive. Other gears seem to be shifting fine including Reverse.
Could this be the Solenoid or do I need to find a new Tranny?
Thanks,
Josh
Old Aug 17, 2007 | 08:22 AM
vzdude's Avatar
DTR's 'Go to Guy'
Several different things can cause that. Need to see if there are any codes related to the solenoid. There is a snap ring that can break in the overdrive unit causiing similar conditions. Typically you will find a piece or two of it in the pan if it does. There is also some wiring inside and outside the pan that can cause it, but they will usually set a code. Get the codes checked and report back.
Old Aug 17, 2007 | 09:09 AM
JIT's Avatar
JIT
Thanks... I just checked it with the ign switch deal and there are no codes. Just says "P done"!
Old Aug 17, 2007 | 09:33 AM
vzdude's Avatar
DTR's 'Go to Guy'
Hmmmm......gonna need a scanner to read inputs and outputs to see if it is trying to engage overdrive, or if its not trying to engage, why not. There are a lot of factors used to determine O/D engagement. Trans temp, speed, throttle position. Not gonna be easy without some sort of scan tool.
Old Aug 17, 2007 | 10:15 AM
John Faughn's Avatar
It could be as simple as a adjustment to the brake peddle sw.
Old Aug 17, 2007 | 05:50 PM
vzdude's Avatar
DTR's 'Go to Guy'
^ That is VERY possible. Forgot about that! There are 2 circuits inside of it though. The lamp circuit may be fine and the cruise/trans circuit may be acting up. Does the cruise work?
Old Aug 19, 2007 | 04:23 PM
J BODY's Avatar
While the brake lamp switch would be a very good place to look for "no lockup", it would not hinder the trans from achieving OD. I don't have much to offer at this point as you've entered "scan tool, good book, DVOM" territory.
Old Aug 20, 2007 | 08:38 AM
I do think that the OD is shut off by the brake sw also , same with cruse .
Old Oct 1, 2007 | 03:37 PM
JIT's Avatar
JIT
Thanks for the ideas guys. I exhaused everything and the tranny was shot! Had it rebuilt and added a Billet TQ so now that I have a warranty I can beat on it a little...
WhiteBeast92
Jul 7, 2009 07:36 PM
72demon440
Apr 27, 2007 10:45 PM
Old Iron
Nov 21, 2005 09:40 AM
scott hall
47
Jul 8, 2005 04:41 PM
jjsj38
Aug 16, 2003 09:57 AM
