ABS and parkin brake light on?!? help
ok i tow a 20ft trailer that gets filled for corn for cows everyother day, this is how they get fed. well towing the other day i realized i lost brakes in the trailor and the ABS and parkin brake lights both came and and will not go off, then i lost signal lights in the truck. i have been workin on it for days with a meter and cant find the problem. I replaced one bad fuse which was the signal lights, but the brake lights on the dash are still on and wont go on...i still have no trailer brakes, and my brake controller doesnt work unless you push the button while driving. I have gone through all fuses, what could be wrong and or what wire would be broken? i need this fixed, this is how my cows get fed. please help
Have you disconnected the trailer and drove around?? Possibly you have lost the speed sensor in the rear pumpkin. I do not know if 95's have that particular sensor, but my 02 did something similar while towing my travel trailer and the speed sensor pick-up had grenaded. It was a fairly cheap and very simple fix that I did myself.
Good luck!
Gary
Good luck!
Gary
Joey-D
Dec 12, 2011 12:52 PM
turbo246
Oct 1, 2007 07:02 PM
mr T
Feb 24, 2007 06:42 AM
