No Oil Pressure Reading
Old Feb 14, 2008 | 11:05 PM
sdsaw's Avatar
I know it's late (9PM Pacific time) but I just went to move the truck and the "check gauges" light is on and oil pressure is not registering. Oil level good. No tappet sounds. Motor sounds normal.
I'm thinking that it's the oil pressure sensor. Can I drive it tomorrow or am I crazy to take any chances.
Thanks, Scott
Old Feb 14, 2008 | 11:46 PM
babyjoe's Avatar
I had the same problem on my 01, guage works then doesn't and bounces around, I installed a manual gauge and its got awesome oil pressure. remove oil fill cap and look for oil on the rockers, listen to the turbo spool to make sure its getting oil, and if its got good oil on the dipstick I'd say drive er but get a manual gauge first thing can even pipe one in quick under the hood to check, hooks in right ontop of the oil filter...good luck man, Babyjoe..
Old Feb 14, 2008 | 11:57 PM
sdsaw's Avatar
Thanks babyjoe,
Restarted it 2 3 times and one of the times it had pressure for about 5 seconds.
Does your factory oil pressure gauge still function?
If it doesn't, what do you do about the "check gauges" light?
Thanks for the reply!
Old Feb 21, 2008 | 05:31 PM
babyjoe's Avatar
I took the insturment cluster out and took it apart, there are four pins on the back of the gauge, just pull them out. It still comes on sometime but not like it did and its only for a second...
mullishacrew
Mar 18, 2012 12:41 PM
megajoltman
Feb 19, 2008 09:41 PM
LJameson
Sep 14, 2007 08:05 AM
ScottMt02
Jul 27, 2007 07:04 PM
sawboywv1
Jun 30, 2003 10:12 AM
