No Headlights
Old Dec 18, 2005 | 01:54 AM
dg95677's Avatar
No Headlights
Hello,
I started my truck this evening to head home. I turned the headlight switch to the on position, but the headlights would not come on. The parking lights, dash lights, fog lights and rear light in the bed all work. I tried the headlight switch many times with no success. Could this be a fuse problem? If so, could you please direct me to the fuse that needs replacing? Looks like I will have to leave the truck here until tomorrow. Any help would be greatly appreciated.
P.S. Truck is a 2001 CTD 4x4 QC 6-speed
Old Dec 18, 2005 | 02:42 AM
phox_mulder's Avatar
Try moving the high beam switch back and forth a couple times.
It is known to go bad in these trucks.
phox
Old Dec 18, 2005 | 11:31 PM
dg95677's Avatar
Thank you for the suggestion. I turned the high beams on and off and the low beams came on.
Old Dec 18, 2005 | 11:54 PM
J BODY's Avatar
Switch is made by Lucas.....the prince of darkness.
Old Dec 19, 2005 | 05:38 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Q: "Why do the British drink warm beer?"
A: "They have Lucas refrigerators"
Old Dec 19, 2005 | 07:26 AM
rammtuff's Avatar
Working on British cars we would always comment:
Electrical by Lucas, Towing by (insert favorite towing company here)
Old Dec 21, 2005 | 05:32 PM
dg95677's Avatar
Fixes?
So, any suggestions for a fix for this problem? Do I need to purchase a new multi-function switch and swap it out or is there a cheaper alternative?
Any suggestions would be appreciated
David
Old Dec 21, 2005 | 06:08 PM
Geico266's Avatar
You are soooo bad!
Old Dec 21, 2005 | 06:44 PM
scottsjeeprolet's Avatar
Sometimes the light switch wire under the column cover comes unplugged.
When mine went up i could tilt the column up and the lights would come on and tilt down off.
Remove the cover on the steering column and look on the left side of all the wires and the purple/white stripe might be loose, i tightened the connector and put some RTV on it to hold it on.
hope this helps.
scotte
Old Dec 21, 2005 | 06:53 PM
infidel's Avatar
David
I've had good luck dousing the switch where the turn signal shaft enters it with aerosol electronic cleaner while working the MF switch back and forth.
Due to the open construction of the switch it's prone to to getting gunked up. One cleaning can keep it working for several years. In fact a brand new switch will probably gunk up as fast as a cleaned one.
Old Dec 24, 2005 | 11:40 AM
neveragain's Avatar
head light electrical problems
The grounds tend to become poor after a number of years, poor headlight!
Extreme Diesel
40
Dec 25, 2006 11:23 PM
Hunter
13
Dec 20, 2002 05:59 AM
kingofdodge7131
Dec 14, 2002 02:43 AM
24
Dec 2, 2002 08:19 AM
