No Cruise Control
Old Apr 24, 2006 | 05:07 PM
74dart's Avatar
No Cruise Control
Cruse control in my brothers truck does not work. It first would floor the acelerator petal when set now it does not work at all. I have ckecked the brake light switch, changed the RWAL sensor in the diff ball, and have replaced the buttons. Is their any thing else I can check or am I looking at a bad pcm. The truck in question is got the same mods as the on in my sig but it is a 97 4x4 not a 96, with factory size tires.
Old Apr 24, 2006 | 05:20 PM
ds1rider's Avatar
I had a problem for a year with mine. Turned out to be a broken vacuum line. A minute later and 25 cents, I was a cruisin.
Old Apr 24, 2006 | 07:05 PM
infidel's Avatar
The vacuum line, wiring and/or the actuator under the driver's side battery tend to get eaten by acid.
Probably the most common cause of CC failure.
Old Apr 24, 2006 | 07:14 PM
74dart's Avatar
Thankyou i will pass the info on.
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
trophystock
Jul 6, 2006 06:28 PM
sam
Mar 31, 2003 09:04 PM
TexasDiesel
Dec 27, 2002 10:47 AM
