NO BOOST
Old Apr 29, 2003 | 03:54 AM
DarrellB's Avatar
NO BOOST
I need some Help please.<br><br>When I turned off the expressway tonight I lost all boost pressure. At WOT it will only build 10psi and will build No boost under 2500rpms. :'( <br><br>I'm thinking maybe a blown intercooler boot or line, bad boost/map sensor or somethings wrong with the Power Max 2 or the EZ. I can't check anything at work since it's raining, so I'm going to have to limp her home where I can get in the dry and check things out. <br><br>Anyone think of anything else I should check?<br><br>Oh yea, It's getting plenty of fuel pressure.<br><br>Help! I have No Boost. :-[<br><br>DB
Old Apr 29, 2003 | 07:07 AM
PourinDiesel's Avatar
Re:NO BOOST
Darrell,<br>It could be a bad map sensor, causing your ECM to defuel.<br><br>Just an Idea.<br><br><br>--Justin
Old Apr 29, 2003 | 07:15 AM
DarrellB's Avatar
Re:NO BOOST
Got it fixed Justin. 8)<br><br>Turned out to be a loose connection on the Edge EZ. I took all the boxes off and put a coating on Dielectric grease on them just to be sure. <br><br>She's back up to 36lbs and running smooth.<br><br>Thanks for the suggestion, I keep a map sensor in the glove box.<br><br>DB
Old Apr 29, 2003 | 07:26 AM
Re:NO BOOST
Glad to hear it!!!<br><br> ;D
HOHN
45
Oct 8, 2005 08:51 AM
triplenickel
Aug 23, 2005 04:01 PM
GTSDave
Jul 8, 2005 09:06 AM
MY WORLD
25
Dec 29, 2004 08:54 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
