no blower motor
Old Mar 27, 2010 | 09:07 PM
James Gunter's Avatar
no blower motor
After replacing the ignition switch electrical portion, I now have no heater blower. I show battery voltage at the connector, and the blower works when I connect it directly to the battery. Any ideas anyone?
Old Mar 27, 2010 | 09:18 PM
07 ThunderRoad's Avatar
Will the blower operate on high speed? If yes it is the speed "resistance wire block" (I forget its proper name). If no go at any switch position than a fuse may have opened when you were working on the ignition switch or you missed a connection. When u checked for voltage at the connector, did u check for the hot to the body of the truck?
Old Mar 27, 2010 | 09:38 PM
no blower motor
I get a test light from the positive battery post to the ground wire at the blower. My meter shows battery voltage at the connector. No blower at any speed.
Old Mar 27, 2010 | 09:43 PM
this is the connector at the blower motor? using a dc volt meter, test at the 2 pins to the blower motor. on hi it will be 12vdc. on lo it will be about 6vdc.
Old Mar 27, 2010 | 10:10 PM
Just checked it on the lower speeds. I get battery voltage 12vdc on all 3 speeds. Does this indicate the resistor mounted in the A/C case is bad?
Old Mar 27, 2010 | 10:20 PM
The meter u are using may be getting a ghost voltage thru the circut, (it makes the meter read). use a test light. the test light uses voltage and draws amps. a ghost voltage can't light it. Test the test light at the battery and note how bright the light is. Then, connect it to the pins in the plug. Let me know if it lights and at what speeds on the switch and if the light gets dimmer at the lower speeds.
Old Mar 27, 2010 | 10:54 PM
from Positive battery to ground on motor I get light. from ground on battery to positive on motor I get NO light at any speed.
Old Mar 27, 2010 | 10:59 PM
I am not trying to be insulting, did u test with the motor plugged into the wiring harness or did u test the wiring harness plug?
Old Mar 27, 2010 | 11:02 PM
no insult taken. motor is unplugged.
Old Mar 27, 2010 | 11:17 PM
Can u find the connector for the blower motor resistors? If so u need to test, with the test light, from the neg @ battery to the resistor plug. Note that only 1 wire will be hot for the speed selected on the switch. Test all speeds, only 1 wire per speed, 1 selected speed per wire. also with the motor unplugged, using an ohm meter set to 100 ohm scale ( if its selectable ) test the resistors. I don't know the pin layout so u will test all possible combinations. If resistor is good the meter will read a reistance.
Old Mar 28, 2010 | 09:29 AM
I get no light on any post on the resistor connector, my meter registers a momentary resistance to just over 1 ohm on any post then drops off to 0 on 200 ohm scale (don`t have 100). I can`t figure how to get the dash panel off to check the switch. Taking the new blower back for a refund. Will check back when the frustration level drops some.
Old Mar 28, 2010 | 04:58 PM
I FOUND IT! The connector at the rear of the ignition switch had a burned contact. Burned to the point it would not complete the circuit to the blower.
I wired around it til I can get another connector and splice it in.
Thanks for your help ThunderRoad. I finally found a manual with wiring schematics in it which certainly helps puzzle these things out.
Old Mar 28, 2010 | 04:59 PM
good deal. I am happy to help.
Old Mar 28, 2010 | 10:58 PM
raymond21's Avatar
Mine did the same thing. I cut the wire out of the connector at the base of the steering column and soldered / heat shrinked it, been good ever since.
Jim Lane
Apr 5, 2020 06:03 AM
RedRocket
May 21, 2004 01:28 PM
Jones0027
13
Dec 18, 2003 01:10 PM
Copenhagenjunkie
Jun 1, 2003 04:20 PM
