new alt no charge
Old Jan 16, 2007 | 09:08 PM
redruM Hauler's Avatar
truck starts and runs fine..... as long as i plug in a battery charger at night... (i am begining to think i have the worlds biggest electric car
Old Jan 16, 2007 | 09:18 PM
53 willys's Avatar
maybe you have a electrical Draw?? pull your negative battery cable and put a test light between the neg battery cable and the neg battery lug/terminal, if the test light, lights up you have a draw.
Have you taken the truck in and had the charge system checked? by a Vat 45 or equal machine or did you just take the alternator in and have it checked?
Old Jan 16, 2007 | 09:34 PM
1-2-3's Avatar
Just a plain ole guy
Quick alt output test. Start truck. Carefully touch screwdriver to back of alternator. If it attratcts like a magnet, it's putting out some amount of voltage.
Old Jan 17, 2007 | 07:33 AM
ticki2's Avatar
With the truck running check with a test light to see if you have 12v to the upper small terminal on the back of the alternator . If you don't you have a wiring problem . If you do , it is either the wiring back to the PCM or the regulator in the PCM . In my case I put on an external regulator and all is good. Do a search in Tech Facts , 1st Generation , External Regulator . Good luck
Old Jan 17, 2007 | 04:11 PM
******... no elec draw... only discharges while driving
charliez... will try thanks
ticki2... i have a bosch alternator 2 posts and a plug
does anybody know where the fuseable link(s) is/are located ?
Old Jan 20, 2007 | 12:20 AM
Old Jan 20, 2007 | 05:59 AM
Rauschbo's Avatar
- wish I knew for SURE where they were, you may be relegated to doing a manual trace of the wires, feel for the links; I am not sure what the would even FEEL like, should be way different than just a wire - somebody posted that they were on the drivers side battery, should be a good place to start...
I 'spose you've been through the alternator connections, did a double check of the Master fuse (140 amp) - (I blew mine once and could only tell by pulling it and slapping an ohmmeter on it, the plastic casing was too old to really see through).....
Good luck, I HATE Sparky Gremlins!
Brian.B
Feb 28, 2012 11:31 PM
Travs94Ram
Jun 16, 2008 05:05 PM
97ramctd
23
Sep 6, 2007 11:21 PM
greenpower
Jan 7, 2007 12:23 PM
z1bigtom
Sep 20, 2004 09:27 PM
