needed crank position sensor (all on backorder)
Old Dec 15, 2008 | 09:57 PM
turbo6justin's Avatar
I am finally closing on my first house on Friday and I need my truck. Last time I used it I was having alternator charging and no tach problems. Easy fix right? It is the CPS on the front of the motor. So I start looking for one and they are on backorder.
Anyone out there have one they could sell and get in the mail today?
I am just a little desperate.
Old Dec 15, 2008 | 10:04 PM
Dinner's Avatar
What year of truck is this for? If it is older than an 01 or 00 it will use the Crank Position Sensor that is located behind the Starter. If it is the 00 or 01 24 Valve, it will use the Cam Position Sensor underneath the Vp44
Someone will correct me on the years of switch over.
Old Dec 16, 2008 | 11:01 AM
infidel's Avatar
Maybe you're having a problem because a 12 valve doesn't have a CPS, what you want is the engine speed sensor, any autoparts has or can get one.
Old Dec 16, 2008 | 07:19 PM
shortkid's Avatar
My oo has a cps behind the starter, just changed it last week.
Roy
Old Dec 16, 2008 | 07:27 PM
Grider Pirate's Avatar
Roy
As does my '99, but his '95 doesn't.
You'll probably get more help in the 12 valve forum.
Old Dec 17, 2008 | 05:53 PM
This is for my '95. As I understand it the sensor on the front of the motor that runs off the 'tone ring'/harmonic balancer is the culprit. It is a magnetic sensor that has about a 8-12" long wire lead with a 3 prong round plug. I am still desperate.
Old Dec 18, 2008 | 08:19 AM
patdaly's Avatar
Justin, check out http://www.rockauto.com go to your year ( 95 ) and look it up, interestingly enough they put it under the ignition section.
That should be what you need, and several aftermarket suppliers make it, so any decent Auto Parts store will have them in stock.
From the cross reference, it looks like they used the same sensor in everything from a Neon to a Ram.
Old Dec 18, 2008 | 10:16 AM
infidel's Avatar
When I needed one the Napa in my little podunk town had five in stock.
It's not like it's a rare item.
Old Dec 26, 2008 | 09:44 PM
Dave Miller's Avatar
I live in a little podunk town also and my Napa ordered one for me for about $75 for my 97. It's called a Engine Speed Senser (ESS) but Napa called it a CPS I believe.
TexasHardcore
Nov 9, 2004 06:41 PM
Blue600
Oct 4, 2004 07:20 AM
redhornet
Jun 17, 2004 01:02 AM
kingofdodge7131
May 24, 2004 01:09 PM
linetrash75
Jan 26, 2004 07:43 PM
