Need some help... truck died
Old Dec 9, 2009 | 01:21 PM
Mechanos's Avatar
Pulled back into the parking lot at work after lunch and my truck started running really erratic and then just died (after throwing some codes).
PCU:
P 0500 - No VSS Signal detected
P 1693 - Companion codes stored
ECU:
1693 - Again
0230 - Lift pump out of range (no big deal, that ones been there for a year since I have the stock lift pump unplug... I have a mechanical lift pump)
1689 - No communication between ECM and injection pump module
Need some help/advise here. Is it a sensor issue or something more serious?
Thanks.
Old Dec 9, 2009 | 01:48 PM
johnh's Avatar
PCU:
ECU:
1693 - Again
Thanks.
1689 means that your vp 44 needs to be replaced, sorry about that..i had the same code along with 1688. the pump control module on the vp 44 is gone
Copenhagenjunkie's Avatar
Thanks.
I got this code when my ez was bad, try unhooking ez.
Old Dec 9, 2009 | 01:52 PM
johnh's Avatar
p1689 could also mean a bad connection, but not likely. is the vp 44 the original??
Old Dec 9, 2009 | 02:05 PM
Mechanos's Avatar
Funny you should mention that. I was thinking the same thing so I just got back in from the parking lot. I unhooked the EZ from the data link connector, but I did leave the other two leads hooked up to the MAP sensor (for the boost fooler portion of the EZ). Drove the truck around the parking lot and seemed to be fine but couldn't really put any load on it. So I parked it (in a tow truck friendly position) and then held the brake and gave it some gas. The truck pulled hard against the brake, built about 20psi of boost, but never faultered skipped or missed a beat.
Going to try to drive it home and stop by an auto parts store to have the codes cleared. Keeping my fingers crossed.
No, not the original VP. I had to replace it once with about 106k on the clock. I now have about 145k on the clock. Had the VP replaced at a Cummins dealer while I was on vacation a couple years ago.
Old Dec 9, 2009 | 08:58 PM
Mechanos's Avatar
When I fired it up go home, it ran fine without the EZ. The check engine light also turned off. Looks like it was the EZ that took a crap at this point.
phal
24
Jul 10, 2009 04:53 AM
wyododge
Jun 22, 2009 10:15 AM
RyanF
Dec 21, 2008 03:07 AM
Nate-03 D
Dec 14, 2005 12:02 AM
Tommy93w350
20
Nov 1, 2005 11:07 PM
