Need help with the wiring harness
Old Nov 28, 2006 | 12:29 PM
NGA Ram's Avatar
I had a short in some wires. Some of the wires in the dash harness that have to do with the brakes burned up. I can fix the wires but the plugs got too hot also. Does anyone know were i can get the plugs or maybe just a damaged harness with out buying a complete harness.
Old Nov 28, 2006 | 04:14 PM
RCW's Avatar
RCW
The harness from a gas rig is identical, just go to a Pick-A-Part junk yard and you should find what you need pretty economically.
Old Nov 28, 2006 | 07:57 PM
XLR8R's Avatar
Did you meltdown with the trailer in tow?
Old Nov 28, 2006 | 08:47 PM
NGA Ram's Avatar
No i didn't. the guy that had the truck before me wired his brake box to the harness plug by twisting the wires together and putting tape around them. He also had a 40 amp fuse in place of the 20 amp fuse for the break lights. Well to say the least i was going down the road and the truck filled up with smoke. Guess what the tape came off the wire and the fuse wouldn't blow. So now i have to repair one heck of a mess and am also redoing anything that had been wired that was not factory.
Old Nov 29, 2006 | 12:00 PM
gmctd's Avatar
Hit your local boneyard and find a suitable '99 Diesel donor - if none, try a '99 gasser, as suggested above.
Patriot_Auto
Apr 21, 2009 01:07 PM
wyododge
Jan 13, 2009 02:25 AM
shrmpboatcptn
May 3, 2007 12:33 AM
ptgarcia
Oct 19, 2006 06:00 PM
xloudnproud
0
May 1, 2006 08:13 AM
