Need Help! Truck running really bad, P0192 maybe quad gauge related?
Old Jun 24, 2008 | 09:48 PM
spooling's Avatar
Ok the truck started running really bad, rough idle, hard starts, loss of power code P0192. I have also noticed that my fuel pressure reading has been all over the place, 0-17 psi fluctuations, when normally she sits around 16psi all the time.
From some research using the handy search button, I think perhaps it could be Quadzilla gauge related. Problem is I didnt install it and no instructions so I don't know exactly what it takes to take it off.
Old Jun 24, 2008 | 10:04 PM
spooling's Avatar
a few other things to add truck will seem to run fine after a couple of starts. Then once I leave the truck for about half an hour its a rough start and rough idle. Smarty tells me P0192 is fuel pressure sensor voltage low. Could I be on the right track assuming this could be quadzilla gauge related?
Old Jun 24, 2008 | 10:58 PM
dj_souvlaki's Avatar
try removing it and see what happens
Old Jun 24, 2008 | 11:38 PM
fullthrottle07's Avatar
po192 is fuel pressure sensor is bad that item is covered under the cummins 100,000 mile warranty thats what the dealer told me. and read my post below on code po193 what others had said to jump my sensor and if it throws code po192 that my sensor was bad it cost right at $600.00 if you buy it from dealer
sqrl$$
May 21, 2011 11:15 AM
05CTD2500
Sep 17, 2008 08:36 AM
coobie
Oct 17, 2005 10:53 AM
