need help on starting circuit
Old Jun 22, 2006 | 08:01 PM
orangeman's Avatar
changed clutsh slave with mopar replacement key would not start truck afterjob it is a2002 3500 cab and chasis saftey pedal switch is making even jumped out switch to no avail can start truck jumping sel what is the smart module for the starting circiut and where is it and can it be reset have already reset battery connections any help app orangeman
found problemwould be the last thing i checked after new key switch and hrs of trouble shooting found wire to 1st relay cut and a in line splice only crimped on one end where slincer alarm system had been installed at dealership must have dissturbed while dooing the clutch job relieved but was mad about quality of alarm job orangeman thanks anyone who was woorkin on this problem
Old Jun 23, 2006 | 07:37 PM
camelracer's Avatar
Orangeman this is what I found in my '02 manual.
Actuation circuit comes from the ignition switch to the clutch switch to the coil in the starter relay in PDC to ground.
Starter solenoid power comes from battery to fuse 9 in PDC to starter relay to starter solenoid.
Starter motor power comes from battery to starter.
Old Jun 24, 2006 | 12:36 PM
orangeman's Avatar
From orangeman
Thanks! Have changed key switch module...no luck...Do you know if there is a nuetral switch for transmission? Fixing to look at starter relay area. Thanks!
Old Jun 24, 2006 | 04:14 PM
orangeman's Avatar
problem found wire crimped only on one end of a dealer installed alarm system. Thanks orangeman
tadcoelec8
Jan 1, 2011 08:59 PM
coreyb64
Feb 17, 2010 07:05 AM
Joe Diesel
Nov 12, 2007 08:59 AM
WACTD
Mar 30, 2006 01:36 PM
eastmentCTD600
Jan 13, 2005 12:15 PM
