Need help moving axle
Old Nov 18, 2004 | 03:11 PM
BigBlue's Avatar
Ok. I'm working on fixing my rear tie bolts (see thread in 2nd gen high performance called lift question) and my axle needs to go forward 2 full inches before everything lines back up. I can move it about an 1" up but that's it. All 3 wheels are choked, parking brake is on, both rear shocks are off and the sway bar is disconnected from the frame. I can't tell if the passenger u-bolts are binding it or the wheel chok on that side. Yall got any ideas on how to move this thing? Thanks for the help.
Old Nov 18, 2004 | 03:13 PM
apache's Avatar
Get yourself a cheap 1 ton comealong from a hardware store.
Old Nov 18, 2004 | 04:25 PM
doodah's Avatar
Blue, You are gonna have to undo both left and right springs u-bolts and lift the truck up higher to re-position the axle right. I didn't know If you where trying this with the one side still bolted up, you might have to much pressure on the 1 side to move the axle where you need it.
Old Nov 18, 2004 | 06:43 PM
BigBlue's Avatar
Well, I got it in. My buddy and I muscled it into place. Truck rides so much better now that the axle is installed square and straight to the truck again.
turfguy
Apr 17, 2014 11:36 PM
case310350
Jun 23, 2010 09:03 PM
workingdog
Cummins Conversions
Nov 3, 2008 08:31 PM
Ghost Ram
26
Jul 17, 2007 07:58 PM
rattle_rattle
Jun 10, 2004 06:27 PM
