Need help with lockup od
Old Nov 21, 2006 | 04:51 PM
antons350's Avatar
Dont know much about lockup trans. Have 92 d350 with cummins. Keeps coming out of od even at 65mph. What could this mean? Trans is new and converter as well. Could this be an electrical issue or?
Old Nov 21, 2006 | 05:27 PM
mopargw's Avatar
sounds like the speed sensor or tps. could also be a loose wire, check the feed line that tells the converter to lock up for looseness.
Old Nov 21, 2006 | 06:55 PM
gman07's Avatar
The stock transmission for a 92 is an A518 (also referred to as a 46RH). Unless the new converter is a lockup unit (not an OEM replacement) it should have a non-lock converter.
OD issues are usually caused by the TPS or VSS. The TPS can be adjusted, as shown here: http://www.piersdiesel.com/Tech1GTPS.htm
Angry Johnny
Aug 23, 2016 05:01 PM
93dieselZak
Jun 16, 2011 06:10 PM
JQmile
Sep 15, 2010 10:43 PM
Cowboy_Customs
May 6, 2008 09:39 AM
bear
Oct 20, 2002 06:56 PM
