Need help on brakes
Need help on brakes
Ok started pulling my brakes off this afternoon and got down to taking the rotor of but i dont have a socket big enough. Does any body know what size i need for the retaing nut on a rotor for a 2000 1ton 2wd?
This is straight out of the book:
"On 2000 and newer models, the hub and bearing assembly is a sealed unit and is not serviceable or adjustable. The hub nut is not reusable."
Sorry man. I know it doesn't help, but was all I could find while looking for the nut size.
the rotor should just come off after the calipers are removed... i used heat on mine.
a small propane torch is enough
Ok I'm not much of a 24 valve expert but aren't the two wheel drive bearings serviceable and the big nut does need to be removed to get at them up till 2000?
If it's similar to the 12 valves the big nut is 1-11/16"
maybe before 2000
Ok ive gotta remove the hub the bearings bad. so i have to buy the whole hub assambly? I see autozone has a bearing listed for the front will this work or is it for a 4wd? It just seems odd that you would make something non servicable such as a bearing
yup thats what i have. to bad you aint in texas ive called everyone within a 100 mile radius and no one has one and the manf. is backordered. It aint total gone so im gonna run with it and take it easy till i can get one in
JImbo1
13
Apr 18, 2003 06:44 AM
