need help
Old Nov 7, 2006 | 09:40 PM
pro_sessions's Avatar
so can i fix this my self and what is a vp
Old Nov 7, 2006 | 09:54 PM
blackdiesel's Avatar
Registered
yes you can, with our help. vp44 is the injection pump. their in the 1000 dollar range and take you 3-5 hours to change out(the first time it can be done in under 2 by some). you will also need a lift pump $150- $500 depending which way you go. AND need to put on that fuel gauge while you at it(if you don't already have one) the instructions are here some where just search for it, or some one will post a link soon
Old Nov 8, 2006 | 03:28 PM
Racer9's Avatar
Yeah, the 0216 is the death sign for the VP44.
Old Nov 8, 2006 | 06:26 PM
sould i get aftermarket parts if i plan on upgrades
Old Nov 8, 2006 | 07:17 PM
Registered
aftermarket parts? like what?
Old Nov 8, 2006 | 08:31 PM
XLR8R's Avatar
Hey Pro - how 'bout a sig!
Old Nov 8, 2006 | 10:14 PM
like a lift or injection pump
Old Nov 9, 2006 | 04:30 AM
Rauschbo's Avatar
LP - absolutely, the FASS and WALBRO both have rave reviews, both will be around $600, the FASS II (pump only, no fancy filtration) will be somewhere around $400...
AS for the VP, there is a standard and a "HRVP" (I think that is what it is called, for Hot Rod VP?) - there have been many mentions of the FedEx electronics package, which is apparently an upgrade to the OEM stuff, and is apparently notably more robust than OEM.
If you do not have one, install a FP gauge at the same time you are doing the swapping of your pumps!
Old Nov 9, 2006 | 07:19 AM
Registered
as far as I know, all ip are rebuilt. (even at the dealer), and they all have the updated electronics on them. You just dont want to get a black one, their from over seas and not as good. I would stick with some one like Gus or Doug both members here, and have good prices. As for the LP I would do something different, it depends on your skill, and budget. You need a fuel presure gauge bad.
Old Nov 9, 2006 | 11:22 PM
where can i get a Hot Rod VP and a FASS. Should i go with 95 gph? I was told i would need new injector to
Old Nov 10, 2006 | 04:26 AM
Rauschbo's Avatar
There are many places to get the new VP from, check out our site advertisers, I think you will need to do a lengthy investigation to compare prices....
As for the FASS, check out the "parent site" at http://www.dieselpp.com, they have a dealer locater there.
A reminder: Gauges! Especially the fuel pressure gauge, which may prevent a recurrence, although the better LP will give you notable margin to this issue...
smokin24v
Mar 18, 2008 01:21 AM
pwrtripls1
Feb 8, 2008 07:25 PM
spooling
Sep 13, 2007 10:05 PM
coupdetat
Jan 17, 2007 09:23 AM
