need help
Old Oct 28, 2006 | 01:59 PM
pro_sessions's Avatar
need help
i have a lot of blue smoke at start up and alot of luging like my turbo wont wind i dont have any clue what could be wrong its a 2001 2500 ext cab and i dont know how to do my sig
Old Oct 28, 2006 | 03:06 PM
plow's Avatar
Fill out your sig so we know what your working on.
Old Oct 28, 2006 | 03:51 PM
Bad Ramer Jamer's Avatar
Go to user cp at top left corner of page. Then edit sig.
Old Oct 28, 2006 | 03:53 PM
Hillcountry's Avatar
Sometimes that can be from a dirty MAP sensor and a dirty IAT sensor. I had that problem for a while and cleaned those sensors and the problem went away.
Old Nov 6, 2006 | 06:05 PM
i tryed the sensor and it still does it
Old Nov 6, 2006 | 08:20 PM
blackdiesel's Avatar
Registered
sounds like a vp.
turn the key on off on off on and watch the odometer. Itll tell you the codes and then report back
Old Nov 6, 2006 | 10:46 PM
it is 1693
Old Nov 7, 2006 | 12:40 AM
H2SRDMB's Avatar
Originally Posted by pro_sessions
it is 1693
there arnt any other codes? if not you need to get to a place where they can read codes with a reader.. auto zone does it for free. dealers may charge! this way you can figure out what the culprit really is
Old Nov 7, 2006 | 07:05 AM
1-2-3's Avatar
Just a plain ole guy
Blue smoke will be oil in the combustion chamber. I'm betting it'll be a turbo issue.
Old Nov 7, 2006 | 07:54 AM
neveragain's Avatar
help
What is the temp range were you are and oil weight are you using? Is your manifold heater coming on for the temp? Hence oil consumption? Or is it just unburned fuel ? Does it go away when the engine is warm.
Old Nov 7, 2006 | 05:53 PM
i dont burn any oil so i dont think its oil
Old Nov 7, 2006 | 07:11 PM
Racer9's Avatar
Lets check a couple simple things. Hows the air filter? OK? Pull the large black tube going to the turbo and look into the turbo. Does the impeller spin? Is there a lot of oil in it? Does it wobble enough to touch the sides?
Have you ever had the valves adjusted?
How many miles. Do you use additive? Do you run it hard every now and then?
The 1693 is just a companion code that tells you you have codes. You'll need a scanner to get the rest. Do you have gauges? Fuel pressure is very important on the 24 valve motors.
Any cold diesel will smoke a little, especially if the outside air is very cold.
Old Nov 7, 2006 | 08:54 PM
the code i got from the scanner is 0216
Old Nov 7, 2006 | 08:56 PM
H2SRDMB's Avatar
i will bow my head. and smoke a cigar in its memory! been there.
check the fuel pressure! and check to see if its is in fact getting fuel thru the pump and filter. it still might survive. but the i.p. is most likely toast.
Old Nov 7, 2006 | 09:19 PM
Registered
just as I suspected. Your vp is toast. better call gus (redstreak) and get ya a new one!
