Need a "COMPUTER" behind air filter (98 CTD 12 valve auto)
Old Feb 16, 2006 | 08:10 PM
12valve's Avatar
Question Need PCM, "COMPUTER" behind air filter (98 CTD 12 valve auto)
In need of a "COMPUTER" behind air filter (98 CTD 12 valve auto)
I bady need the:
Computer on the firewall, behind the air filter!
anybody can tell where to buy it??
It's a 98 Dodge cummins 12 valve with an automatic transmision!
It came with a computer from a 97 and it wont work! (now the tranny wont take OD, and the gauges dont work, no AC! etc!
Thanks a lot in advance for any help!!!!! please help!
Old Feb 16, 2006 | 08:23 PM
Racer9's Avatar
Try auto parts stores like NAPA, or hit the "recycling" yards for a used one.
Old Feb 16, 2006 | 08:27 PM
Stamey's Avatar
It is called a PCM. Check out www.car-part.com.
Chris
Old Feb 16, 2006 | 09:40 PM
infidel's Avatar
They are hard to come by because they rarely fail.
Don't be surprised if the dealer is your only option.
Most times a used one still needs to be reprogrammed by the dearer for your specific setup.
Old Feb 19, 2006 | 01:02 PM
12valve's Avatar
as from what you say, i believe it needs to be reprogrammed!
does the truck need to be brought to the dealer for it, or, simply the vehicle VIN (serial number) ?
and another question. someone told me i need to know if its federal emission or california emission, how can i find out what my truck is?
thanks!
Old Feb 19, 2006 | 01:33 PM
darkvader's Avatar
The sticker under the hood should tell you if it is ca emmissions.
Clark
Old Feb 19, 2006 | 03:11 PM
infidel's Avatar
thanks!
The only one I had reprogrammed the dealer said the whole truck needed to be brought in.
I found out later they removed the PCM and took it to the Cummins dealer down the street to be reprogrammed.
Old Feb 20, 2006 | 10:57 PM
12valve's Avatar
Clark
i looked all over the sticker, couldnt find it! it couldnt read the top line! almost gone...
thanks anyway!
we sent our old computer in for core, and ordered a new one, gave him our serial number (vin) and vehicle description, hopefully it will work!
does that have to do with: that the truck doesnt take of in 1st gear? it takes of in 2nd or so!
Old Feb 21, 2006 | 06:37 AM
Stamey's Avatar
Have we established why you think you need a PCM? Is it because of tranny shifting problems?
Chris
Old Feb 21, 2006 | 10:13 PM
12valve's Avatar
Chris
YES!
the tranny doesnt take overdrive, no gauges inside work! the alternator doesnt charge the battery, the A/C doesnt work!
And a shop near here told me it was the PCM! I guess they tested it...
but I dont know! they ssid the truck doesnt come with the right one. it has a 97 PCM! (different dash!)
Old Feb 22, 2006 | 06:44 AM
Stamey's Avatar
OK, that does sound like a PCM could be the culprit. Hate to second guess you, but we have seen things mis-diagnosed many times before on this site.
Check out car-part.com. There are lots of them on there, cheap. You need to know a few things about the truck, such as what kind of ABS and air bags, but once you narrow it down on the site you can call the supplier and probably get better info from him.
Chris
Old Feb 22, 2006 | 07:19 AM
TerryS's Avatar
Before you put a new pcm in you better figure out why the old one went, Check your grounds!
Old Feb 22, 2006 | 05:08 PM
12valve's Avatar
good point! where and what should i check? and how...
the new one should arrive in 2 days!
thanks!
MikeRP
79
Nov 21, 2016 10:19 PM
Wildhog
13
Aug 4, 2008 08:07 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
12valve
19
Feb 26, 2006 07:49 PM
bigbaddiesel
Mar 6, 2003 01:26 PM
