Need assistance pretty quick!
Old May 14, 2010 | 11:53 AM
Bo-man's Avatar
Ok. so i was told by a diesel tech who tested my tank that i have algae. my truck wouldnt start unless i sprayed it. if i changed the fuel filter and emptied the fuel out of the canister it would start. it also showed my lift pump wasnt what it should be so i just installed a FASS. it started and ran great for a day. then wouldnt start unless i gave it the can of incentive. i emptied the filters on the fass and it started fine a most of the day then wont start again. could algae be doing all this? it runs fine once its started. did it only start because the complete FASS system was clean? Help please
Old May 14, 2010 | 11:58 AM
1-2-3's Avatar
Just a plain ole guy
Clogged filters. yep. What treatment did you put in the tank? It aint gonna just go away.
Old May 14, 2010 | 12:02 PM
Bo-man's Avatar
Well i did some just normal diesel treatment on the last tank i ran. Randy at daves diesel gave me Biocide which i just started runnin thru. should i drop the tank and clean it?
Old May 14, 2010 | 12:04 PM
patdaly's Avatar
What he said. Algae is living, and unless you completely KILL it, you will never filter your way out of it.
You need to hit it hard with a good biocide, available from truck stops, many auto stores, Implement stores, etc.
I would have thought your mechanic would have advised you to use it....
Old May 14, 2010 | 12:06 PM
patdaly's Avatar
Wouldn't hurt to drop the tank and clean, you still need to run the biocide. Wouldn't hurt to hit it a few times even after you have it under control to make sure the last of the little buggers are stone cold dead.
Old May 14, 2010 | 12:17 PM
Bo-man's Avatar
They said that i would notice the black booger lookin stuff in the filters and stuff. it didnt really seem that bad, but something was def there.
thejoker502
Sep 18, 2006 01:23 PM
Murf
Aug 10, 2006 10:29 AM
hump
Jun 21, 2006 01:40 PM
jrs_dodge_diesel
Nov 8, 2005 04:04 AM
Patrick Campbell
Nov 29, 2004 12:40 AM
