A mysterious SCRAPING front end-bearing?
Thanks for the info. I know this is not my thread, but i am getting desperate for info to get this fixed before i start thinking it is time to let it go. I imagine taxidermyman probably feels the same way. I am going to put on lift this weekend a check it out myself. I will probably go ahead and replace u-joints just to try and eliminate possible causes. Tim
Hope this helps!
Jack up the front wheels, crank the steering to one side, then try to spin each front wheel. If a u-joint is starting to seize, you will feel resistance to turning while the steering is cranked.
Apart from that, it may help to raise all four wheels on jack stands, then run the truck in 4wd and listen to the wheel bearings with a stethoscope. If the noise is as bad as you mention though, a bad wheel bearing will probably have play that you can feel by shaking the wheel.
FYI all you guys , the easiest and most accurate way to check your wheel bearings, if they are not totally shot and flopping all over the place , is to jack up whichever wheel you think it is , hold the coil spring with one hand , and spin the tire with the other , if you can "feel" the bearing as it turns , it's bad.
I wont get to work on my truck till tomorrow but i will definatly do what you guys are saying. The one hub assy i replaced was bad for sure so evidently i have multiple problems. Tim
dieselcarpenter
Jun 11, 2011 06:03 PM
PaulDaisy
26
Dec 22, 2006 12:38 AM
