Is my cummins going to DIE?
Old Feb 15, 2004 | 06:50 PM
Haulin_in_Dixie's Avatar
Let the truck sit overnight. Without starting it, get under it and loosen the drain plug. Oil floats so the antifreez, if any will settle to the bottom. If there is any in the pan it will come out first. If you do have antifreeze it probably means a bad head gasket or a cracked head.
Old Feb 15, 2004 | 07:28 PM
thumper 549's Avatar
I not a bil oil sample man.....but I THINK I would pull a hot one and see what ya get cause antifreez wipes out bngs. fast!
Old Feb 15, 2004 | 08:55 PM
amartinson's Avatar
I agree with the above. It will ease your mind to have the oil sampled. Find your nearest big truck or off-road diesel shop and get an oil analysis (sampling) done to answer your concerns.
Old Feb 16, 2004 | 09:15 AM
infidel's Avatar
Did you wash your engine recently?
Many folks have reported the same thing, seems that wash water in the bottle can pick up a green tinge from the oil.
Old Feb 16, 2004 | 05:27 PM
bama's Avatar
after its running and hot,,pull the oil filler cap off and look up on the inside of the cap,if theres water getting in the oil,there will be moisture in the cap.when hot the water turns to a steam and rises to the highest point,which will be here.the analysis would be a good idea too.can anyone say the average cost of having an analysis done?
Old Feb 16, 2004 | 05:51 PM
DPG's Avatar
DPG
Oil Analysis isn't all that costly, about $15.00 I believe.
DTR-username
Oct 3, 2016 07:46 PM
rebal
Jul 18, 2012 07:33 AM
loya 3500
Feb 21, 2012 02:29 PM
Camarokid77
Aug 26, 2010 10:30 PM
bsj04
22
Sep 19, 2007 11:53 PM
