Munched power screw cover
Old Oct 1, 2004 | 04:53 PM
mhuppertz's Avatar
I messed up my power screw cover trying to get it off. Is it necessary?
Old Oct 1, 2004 | 06:01 PM
apache's Avatar
The tin cover over the screw is not needed, nor is the collar when removed. just make sure the lock nut is sufficently tight.
Old Oct 6, 2004 | 01:55 PM
Redleg's Avatar
It's use went out the window with the warranty.
Old Oct 6, 2004 | 07:18 PM
mhuppertz's Avatar
I'm putting a 3200GSK in it. The warranty is dead!
Old Oct 9, 2004 | 10:50 AM
JKM's Avatar
JKM
what is this power screw , and what does it do? and what trucks is it on?
thanks.
Old Oct 9, 2004 | 10:58 AM
mhuppertz's Avatar
It increases the fueling across the RPM range. I don't know if your 2nd gen pump has it, but the VE pump does for sure.
Old Oct 11, 2004 | 06:09 PM
thanks.
You don't have one. '89 - '93 only.
Old Oct 11, 2004 | 07:06 PM
JKM's Avatar
JKM
I have a friend with a 93 1st gen , and he is looking for some more power.
where is this screw , and how many turns would it be good to start off with?
I have turned up tractors before using the fuel screw , but not a truck yet.
Old Oct 11, 2004 | 08:23 PM
mhuppertz's Avatar
First, there is a lock nut on the screw that needs to be loosened. It can be a bugger to get to. Once that is done, remove the screw. You will see a limiting collar crimped to the screw. This is a present from the EPA. Carefully grind the collar until it starts to spin on the screw. Remove it. Be extra careful not to ding the threads on the screw. Use the jam nut to chase the threads, then screw it all the way in (carefully). Bear in mind that the injectors may become a limiting factor and turning the screw in may only have negligible effect.
Old Oct 12, 2004 | 10:25 AM
JKM's Avatar
JKM
Where on the pump is this screw located?
and did i understand that you must turn the screw all the way in?
Old Oct 12, 2004 | 01:37 PM
mhuppertz's Avatar
You don't have to turn it all the way in, you can go in 1/4 turn increments if you like. I just usually go for it and crank it in.
I'll try to send you a picture later today that has the screw location.
Old Oct 12, 2004 | 02:39 PM
mhuppertz's Avatar
kcastun, here's the link:
http://www.dodgeram.org/tech/dsl/mo...er/Power_ve.htm
Old Oct 13, 2004 | 02:52 PM
JKM's Avatar
JKM
thanks a million , DTR rocks!
jmd4993
Jun 22, 2013 07:36 AM
loudcummmin
Oct 3, 2005 02:44 PM
dieselnewbie
Dec 11, 2004 03:38 PM
apache
Feb 11, 2004 12:25 AM
