muffler removal
muffler removal
im tryin to take the muffler off my truck and have run into a prob. i have all the hangers disconnected from the muff, but the clamp just in front of the muff pinched the pipe to the point i cant pull it off. anyone ever pulled one off? i hate to resort to a cutting torch as i might decide to put it back on.
You could cut it, and get a coupler that is 4"IDx4"OD and slip it on. Just cut the pipe right at the muff coupler. Not sure if yours is like mine were its 4" from the cat to the muff, since yours has a resonator, im not sure. But all you have to do is measure yours and its the same principle.
thanks a lot guys........me and my buddy got it with LOTS of torch heat and LOTS of wiggling. took it for a test run and sounds cool with the naked resonator. noticed 100 deg lower egt on avg. and more power in top end. i dont think im hurtin nething bye just removing the muff am i?
It's too late now, but I just removed my exhaust system and I cut longitudinal slots/slits/cuts in the pipe which made for easy removal. When I reinstalled, the clamps compressed the pipes back together. I used a 1/8" grinding wheel on my 4.5" grinder to make the cuts and was careful to only cut through the outer pipe.
timk006
Oct 13, 2006 03:49 PM
Jmac
Sep 9, 2006 10:23 PM
Patrick Campbell
Mar 23, 2005 01:29 PM
commonrail
Oct 22, 2004 07:47 PM
w4xtc
24
May 5, 2003 04:36 PM
